macro to print all open documents?
tomholman
Post by tomholman »
Is there a macro that will print all open documents on the currently selected printer?
Thanks.
Re: macro to print all open documents?
The following macro should do it. Since I don't really want to print out a lot of stuff, I haven't really tested this.
$openDocs = Document.openDocuments
foreach $doc in $openDocs
$doc.show
File:Print
Press Default Button
tomholman
Post by tomholman »
Thanks very much. It worked perfectly.
