problem with installing new version
monicafytam
Post by monicafytam »
I was asked to update new version of nisus express. Did it and now it's frozen, I am not able to open the application "because it may be damaged or incomplete". What happened and what could I do?
Re: problem with installing new version
It sounds like the download was corrupt, or the update process didn't complete successfully. Either way, it would be best if you downloaded the update manually:
http://nisus.com/update/express.php
Just replace your existing (damaged) application with the new one. Let us know if you have any more troubles.
