I would like to insert a short line between my footnotes and the body of the page. Is this possible to do using Nisus?
Thanks!
Nate
Footnote separator
- Jester
Re: Footnote separator
What do you mean by "short line"?
Word allows you to insert a two-inch line between footnotes and the body.
And Nisus doesn't ? It does for me. You can adjust the kind of line you get to separate footnotes from the text if you switch to Style sheet view, and choose the footnote style.natan wrote:Word allows you to insert a two-inch line between footnotes and the body.
- NWP Footnote style sheet view.jpg (55.09 KiB) Viewed 7095 times
Thanks! That's exactly what I was looking for.
