centering help
centering help
How is text centered vertically on a page? The horizontal (left-right) centering is straightforward, but I've looked in the NWP User's Guide and in the forum and can't find anything on centering text vertically (top-bottom).
Re: centering help
There's not really any quick and easy way to center text vertically on a page. If you don't intend to have any other content on the page, you could insert a table with a single table cell, where within you may vertically center text. You'll want to increase the height to that cell to that of a single page, and probably make the cell borders invisible.
There's also the makeshift approach: inserts lots of newlines and eyeball it. Or play with the paragraph spacing.
Re: centering help
Thanks for the advice. It's no big deal to use the eyeball technique; I was just wondering if there was a command somewhere that could be used.
But far be it from me to mutter anything about vertical rulers--they're about as useful as the old Microsoft talking paper clip.
Re: centering help
Oh oh. Now, you raised the hackles of our beloved Geoff. Just when it seemed he had cooled a little.robertb wrote:
