arab numerals - roman numerals
js
Post by js »
Has there ever been a macro to output roman numerals from arab ones and vice versa? Or maybe this is not as simple as that?
Kino
Re: arab numerals - roman numerals
Post by Kino »
Old macros written before NWP 1.3; perhaps they can be simplified. Both work on selected numerals.
### Arabic Numeral to Roman Numeral ###
# Convert Arabic numeral(s) in selection(s) to Roman numeral(s).
# Only numerals from 1 to 3999 are supported.
Require Application Version '3.2'
$thousands = ','
$comma = System Property 'use comma for decimal point'
if $comma == true
	$thousands = '.'
$findArabicNumerals = '[0-9]+(?:[0-9' & $thousands  # construct a find expression for Arabic numerals
$findArabicNumerals &= '])*'
$numfound = Find All $findArabicNumerals, 'Es'  # E: PowerFind Pro; s: in selections
if ! $numfound
	Exit 'No Arabic numeral found in selection(s), exit...'
$selections = $doc.textSelections
$romanIXCM = Array.new ('I', 'X', 'C', 'M')  # create an array
$romanVLD = Array.new ('V', 'L', 'D')  # create another array
$errorMessage = ''
foreach $sel in reversed $selections
	$validArabicNumeral = true
	$roman = ''
	$arabic = $sel.subtext
	$arabic.replaceAll $thousands, ''
	if $arabic > 3999
		$validArabicNumeral = false
		$errorMessage &= 'Cannot convert ' & $sel.subtext
		$errorMessage &= " which is greater than 3999.\n"
	if $arabic < 1
		$errorMessage &= " which is less than 1.\n"
	if $validArabicNumeral == true
		$arabic = $arabic.split ''
		$i = 0
		$j = $arabic.count - 1
		while $i < $j  # reverse values in $arabic
			$arabic.swapValuesAtIndexes $i, $j
			$i += 1
			$j -= 1
		$limit = $arabic.count
		$i = 0
		while $i < $limit
			if $arabic[$i] == 4
					# When $i is 0, $romanIXCM[0] is "I" and $romanVLD[0] is "V".
				$roman = $romanVLD[$i] & $roman
				$roman = $romanIXCM[$i] & $roman
			elsif $arabic[$i] == 9
				$roman = $romanIXCM[$i+1] & $roman
			elsif $arabic[$i] < 4
					# When $i is 2, $romanIXCM[2] is "C" and $romanIXCM[2+1] is "M".
					# When $i is 3, $romanIXCM[3] is "M" and $arabic[3] is "1".
				$c = $arabic[$i]
				while $c > 0
					$c -= 1
			else  # if $arabic[$i] is 6 or 7 or 8
					# When $i is 1, $romanVLD[1] is "L", $romanIXCM[1] is "X"
					# and $arabic[1] is "8". So ($arabic[1] - 5) = 3.
				$c = $arabic[$i] - 5
				while $c > 0
					$c -= 1
			$i += 1
	$roman = Cast to String $roman
	$sel.text.replaceInRange $sel.range, $roman
if $errorMessage
	Exit $errorMessage
### Roman Numeral to Arabic Numeral ###
# Convert Roman numeral(s) in selection(s) to Arabic numeral(s).
# Only numbers from 1 to 3999 are supported.
Require Application Version '3.1'
$errorMessage = ''
if ! $selections.firstValue.length
	Exit 'Nothing selected, exit...'
$errorMessage = ''
$roman2arabic = Hash.new
$roman2arabic{'I'} = '1'
$roman2arabic{'V'} = '5'
$roman2arabic{'X'} = '10'
$roman2arabic{'L'} = '50'
$roman2arabic{'C'} = '100'
$roman2arabic{'D'} = '500'
$roman2arabic{'M'} = '1000'
	$roman = $sel.subtext
	$roman.replaceAll '\x20|\xA0', '', 'E'
		# Transformm, for example, "M CM XL III" to "MCMXLIII"
		#  \x20  space
		#  \xA0  no-break space
		#  |     OR operator
	$matched = $roman.find '(?x)  # See if it is a valid roman numeral
				(?: M{1,3} )?
				(?: D?C{1,3} | C?[DM] )?
				(?: L?X{1,3} | X?[LC] )?
				(?: V?I{1,3} | I?[VX] )?
			)$', 'Ei'  # (?x) eXtended mode (ignore white space)
		#  ^ strings start
		#  (    )  group (captured)
		#  (?:  )  group (not captured)
		#  ?       zero or one time
		#  {1,3}   match at least 1 but not more than 3 times
		#  |       OR operator
	if ! $matched.length # if $matched is empty, then it is an invalid roman numeral
		$errorMessage &= "\"$roman\" is not a valid Roman numeral.\n"
	else
		$roman.replaceAll '(?=I[VX])|(?=X[LC])|(?=C[DM])', '-', 'Ei'
			# insert "-" before
			#   "I" preceding "V" or "X",
			#   "X" preceding "L" or "C" and
			#   "C" preceding "D" or "M"
			# because they are negative
			# to transform "MCMXLIII" into "M-CM-XLIII"
		$roman.replaceAll '(?<!-)(?!-)(?=\S)', '+', 'E'
			# insert "+" before non-minus character
			# and non-minus character
			# to transform "M-CM-XLIII" into "+M-C+M-X+L+I+I+I"
		$range = Range.new 0, $roman.length
		$roman.transliterateInRange $range, $roman2arabic  # replace "I" with "1"
		$i = 0
		$plus = $minus = Array.new
		$plusSels = $roman.findAll '(?<=\+)[^+-]+', 'E'
		foreach $n in $plusSels
			$plus.appendValue $n.subtext
		foreach $n in $plus
			$i += $n
		$minusSels = $roman.findAll '(?<=-)[^+-]+', 'E'
		foreach $n in $minusSels
			$minus.appendValue $n.subtext
			$i -= $n
		$sel.text.replaceInRange $sel.range, $i
if $errorMessage  # if $errorMessage is not empty
	Exit $errorMessage  # show $errorMessage
js
Post by js »
I can see that this is not so simple indeed.
I find a problem on the roman Arabic side though. The macro does not execute and complains about the length property "requiring an object under $matched".
Kino
Post by Kino »
js wrote:The macro does not execute and complains about the length property "requiring an object under $matched".
That is no-break spaces inserted by php. Run
Replace All '\xA0', '\x20', 'E'
on your macro file.
js
Post by js »
Thank you. that works fine now.
I have a suggestion to make: Probably it would be a good idea to provide for lowercase roman, as is often used in Prefaces. For Roman -> Arabic one can of course just start the Macro with the line "Convert:To UPPERCASE", while for Arabic -> Roman the (multiple) selections should be kept to change from upper to lower case if needed.
Kino
Post by Kino »
js wrote:for Arabic -> Roman
Duplicate the macro and just make lowercase the definitions of $romanIXCM and $romanVLD, i.e.
$romanIXCM = Array.new ('i', 'x', 'c', 'm')
$romanVLD = Array.new ('v', 'l', 'd')
Groucho
Post by Groucho »
You can specify which case with a prompt. Substitute this piece of code:
$Case = prompt options "Do you want roman numerals to be uppercase or lowercase?", "", "OK", "UPPERCASE", "lowercase"
if $Case == "UPPERCASE"
	elsif $Case == "lowercase"
	$romanIXCM = Array.new ('i', 'x', 'c', 'm')  # create an array
	$romanVLD = Array.new ('v', 'l', 'd')  # create another array
for this
Henry.
I know Kino is a very clever person, and excellent macro writer. So Roman numerals are much too stupid a technology for him. I think his approach to this problem is way too obscure. Sometimes less is more.
So here is my approach. I have stolen Kino's excellent approach to handling the input, but I replaced the actual conversion with what I think is a much more intuitive approach. This code is also certainly easier to maintain.
$thousands = ','
if $comma == true
	$thousands = '.'
if ! $numfound
$errorMessage = ''
	$roman = ''
	if $arabic > 3999
	if $arabic < 1
		while $arabic > 999
			$arabic -= 1000
			$roman &= ‘M’
		if $arabic > 499
			$arabic -= 500
			$roman &= ‘D’
		while $arabic > 99
			$arabic -= 100
			$roman &= ‘C’
		if $arabic > 49
			$arabic -= 50
			$roman &= ‘L’
		while $arabic > 9
			$arabic -= 10
			$roman &= ‘X’
		if $arabic > 4
			$arabic -= 5
			$roman &= ‘V’
		while $arabic > 0
			$arabic -= 1
			$roman &= ‘I’
		$roman.findAndReplace ‘DCCCC’, ‘CM’
		$roman.findAndReplace ‘CCCC’, ‘CD’
		$roman.findAndReplace ‘LXXXX’, ‘XC’
		$roman.findAndReplace ‘XXXX’, ‘XL’
		$roman.findAndReplace ‘VIIII’, ‘IX’
		$roman.findAndReplace ‘IIII’, ‘IV’
if $errorMessage
	Exit $errorMessage
phspaelti wrote:So Roman numerals are much too stupid a technology for him
haha, yes, Roman numerals are a pain to work with. I don't know anything about the history behind them, but they seem quite impractical as compared to Arabic numbers.
It'd be nice if the macro language gave a coder access to all the built-in number formatters, though I don't think such a feature would be used often.
Well I think it is probably wrong to think that Roman numerals are numbers in any sense that we know. They really just an abbreviatory way to write out numbers as words.
One thing though is that Roman numerals reflect pretty directly the numbers as represented on an abacus. Presumably Romans would never have done math on paper the way we do, but would have done all math on an abacus.
Anyhow, my last attempt at this macro was a bit too primitive. Here is a slightly improved version that makes use of a hash:
$thousands = ','
if $comma == true
	$thousands = '.'
if ! $numfound
$errorMessage = ''
$romanNumerals = Hash.new 1,‘I’, 5,‘V’, 10,‘X’, 50,‘L’, 100,‘C’, 500,‘D’, 1000,‘M’
$romanDigitValues = $romanNumerals.keys
$romanDigitValues.sort
	$roman = ''
	if $arabic > 3999
	if $arabic < 1
		foreach $romanDigitValue in reversed $romanDigitValues
			while $arabic >= $romanDigitValue
				$arabic -= $romanDigitValue
				$roman &= $romanNumerals{$romanDigitValue}
if $errorMessage
	Exit $errorMessage
And here also a version for the reverse conversion. Again I used the input/output of Kino's macro, and just 'simplified' the conversion. I also 'loosened' the types of numerals the macro accepts.
$errorMessage = ''
$errorMessage = ''
$romanNumerals = Hash.new ‘I’,1, ‘V’,5, ‘X’,10, ‘L’,50, ‘C’,100, ‘D’,500, ‘M’,1000
		# Transform, for example, "M CM XL III" to "MCMXLIII"
		#  \x20  space
		#  |	  OR operator
	$isRoman = $roman.find '(?x)^(
			(?: M*)?
			(?: D?C{1,4} | C?[DM])?
			(?: L?X{1,4} | X?[LC])?
			(?: V?I{1,4} | I?[VX])?
				)$', 'Ei' #  ^ strings start
		#  |	 	OR operator
	if ! $isRoman
	else
		$romanLetters = $roman.split ‘’
		$arabic = 0
		$lastLetterValue = 0
		foreach $letter in $romanLetters
			$letterValue = $romanNumerals{$letter}
			if $lastLetterValue < $letterValue
				$arabic -= $lastLetterValue
			else
				$arabic += $lastLetterValue
			$lastLetterValue = $letterValue
		$sel.text.replaceInRange $sel.range, $arabic
