Borderless printing of images
KieranH
Post by KieranH »
Hi
Currently working on paper where the text is to be indented, while a strip of images is to be inserted down the long edge of the page, to be printed full-bleed on a borderless printer.
I have set the text indent in the styles, and have created a new "Image" style with no indents. I am struggling to get the images to print to the edge of the page however.
Is there a way to make the margins less than 0.42cm (i.e. 0 cm)?
I also can't get the image tight against the edge of the margin. There is always a slight white gap. Is there a way to overcome this?
Many thanks
Kieran
Re: Borderless printing of images
It sounds like you are putting the images in-line. I would make the images float. This allows you to have the images in the margin, and even overlapping the edge of the page.
KieranH
Post by KieranH »
Fantastic phspaelti.
Thanks for that. Sometimes the simplest things are the easiest to overlook...
