How to customize header ?
design63
Post by design63 »
Hello,
In order to write a thesis, can we customize the appearance of headers, like adding an underline or other things ?
Thank you
Re: How to customize header ?
Have you tried using styles? You can adjust the styles to your liking using the Style sheet view.
Or perhaps you are talking about a separator line (to separate the header from the document)?
The following methods can be used:
  • Use a leader tab
  • Insert a line graphic (You'll have to make the graphic in another program though.)
  • Use a (one cell) table with only one cell border set
Hope these suggestions are helpful.
Philip
design63
Post by design63 »
In effect I talked about a separator, your answer has been very helpful.
Thank you very much.
