If you don't go right, what's left? Right?
hatchmo
Post by hatchmo »
I copied and pasted text from a normal Web page and ended up with a document that reverses
the right and left arrow keys. This sounds like a problem similar to the one in this thread:
http://www.nisus.com/forum/viewtopic.php?t=1300
What is going on, and how can I reverse the reverse? I could paste plain text, but that would mean retyping a lot of links inside the copy.
Check out this copy of the document:
leftarrowright.rtf.zip
The arrow keys are reversed inside this document.
(3.24 KiB) Downloaded 442 times
Al Hatch
Re: If you don't go right, what's left? Right?
That is because the natural direction of the language has been overridden by the Right to Left button as indicated by the arrow:
To regain natural direction, select the text and apply the Natural direction button in the middle (to the left of the Right to Left button).
