.nwm opening in TextEdit?
jb
Post by jb »
Not so long ago, Nisus Macro files (.nwm) opened automatically in Nisus when double-clicked.
But now they open in TextEdit. What did I do?
I thought I saw something not too long ago about this, but perhaps I dreamed. Sorry if I missed it.
When I open the Info panel (CMD-I) for any given .nwm file and attempt to direct the OS to open all such files with Nisus, it tells me that all *rtf* files will be opened with Nisus. Huh?
Thanks
Re: .nwm opening in TextEdit?
Although internally Nisus Macro files are RTF data, that is odd. I thought OSX differentiated files by their extension. What version of OSX are you using?
jb
Post by jb »
Hi, Martin.
I have 10.5.8
loulesko
Post by loulesko »
This is a problem that I read somehwere had to do with the Apple OS. even using Command-I to change the Open with choice is failing for some reason. Do a google search.
Bob Stern
Post by Bob Stern »
Sometimes the global "Open With" setting in "Get Info" works more reliably if you first apply it to just the selected document, close the Get Info window, then re-open Get Info and then click the button to "Change All".
jb
Post by jb »
The problem is actually worse than it sounds.
If I Get Info on a .nwm file and set to open with Nisus and then click Change All (whether I've closed the Get Info and reopened or not), the setting for the file in question *reverts to TextEdit*. wtf?
I take it that this is an OS problem so I won't hold my breath for a fix.
Kino
Post by Kino »
Perhaps you can fix it by using a free preferences pane Default Apps.
http://www.rubicode.com/Software/RCDefaultApp/
Install it, open it, switch to Extensions tab and choose Nisus Writer Pro as the Default Application for nwm. If nwm is not listed, add it.
Also, try to rebuild Launch Services database using a utility such as Onyx.
jb
Post by jb »
Thanks. This seems to have done the trick. :)
