Every semester, I create a syllabus for my classes that includes a table with a list of dates and assignments for those dates. I have always done this by hand. Would it be possible to have a macro spit out a list of days/dates within a certain range (for MWF and T/Th) so I don't have to do this by hand? Something like
Monday 8/24
Wednesday 8/26
or
Tuesday 8/25
Thursday 8/27
Thanks in advance!
Class Calendar
Re: Class Calendar
Does this work as you expected? It will ask you to specify the first date, the last date and days of week and insert a table at the current insertion point (in a new document if there is no open document).
This macro does not check the validity of date format and that of a date itself. So you may get an unexpected result or an error if you give a wrong one. E.g. "2009-4-31" (wrong date in the valid format).
This macro uses Perl because Nisus Macro language does not have a command for generating an arbitrary date object and properties such as year, month, day are Read-only. I hope these limitations will be removed in a future version. Also I'd like to have a command such as
which will prompt a dialog box having input fields with stepper for date and time, something like those in Date & Time system preferences pane.
Require Pro Version 1.3
$namesOfDay = Array.new
$namesOfDay[0] = Date.nameOfWeekday 7
$i = 1
while $i < 7
$namesOfDay[$i] = Date.nameOfWeekday $i
$i += 1
$indexToName = Hash.new
foreach $i, $n in $namesOfDay
$indexToName{$i} = $n
$now = Date.now
$today = $now.year & '-'
$today &= $now.month & '-'
$today &= $now.day
$date1 = Prompt Input 'From...', '', '', $today
$date2 = Prompt Input 'To...', '', '', $date1
$date1 = $date1.split '-'
$date2 = $date2.split '-'
$checked = Prompt Checkboxes 'Check names of day', '', '', $namesOfDay
if ! $checked.count
exit 'No item checked, exit...'
$checkedNames = Hash.new
foreach $name in $checked
$i = $namesOfDay.indexOfValue $name
$checkedNames{$i} = 1
$output = ''
Set Exported Perl Variables 'date1', 'date2', 'checkedNames', 'indexToName', 'output'
begin Perl
use Time::Local;
$i = timelocal (0, 0, 12, $date1[2], $date1[1]-1, $date1[0]);
$j = timelocal (0, 0, 12, $date2[2], $date2[1]-1, $date2[0]);
while ($i <= $j) {
@lt = localtime($i);
if (defined $checkedNames{$lt[6]}) {
$output .= sprintf ("%s\t%01d/%01d\t\n", $indexToName{$lt[6]}, $lt[4]+1, $lt[3]);
$i += 86400;
if $doc == undefined # if no document is open...
Document.new
Insert Text $output
Menu ':Table:Convert to Table'Code: Select all
$dateObject = Prompt Date 'Message', 'Detail', 'Button', $defaultDateObjectRe: Class Calendar
I neglected to respond, but yes yes yes! This is perfect!
