"Complete List" Macro
Kino: I have read some of your replies and suggestions, thanks. They encouraged me to write this request to you, if you could write a new macro?
A new macro, let's call it Complete List, where the macro will be able to:
a. list every word (case sensitive)
b. list the number of frequency next to the word (italic style)
c. list the page number next to the frequency number (plain style)
If there are more than one frequency in a given page, let the number of frequency show and the page number to follow, for example:
- California, 6–4,8,9,9,11,12.
The dash between the frequency and the page number is "n-dash", so the processor won't hyphenate.
I am aware of Index feature in Nisus, but, correct me if I am wrong, with Indexing, you have to select the words to be indexed!! But with the macro I am suggesting, you either Select All, or not, just by launching the macro a new file should open up with the list created.
Re: "Complete List" Macro
This is a quick attempt at such a macro:
Hopefully it's of some use.
$frequency = Hash.new
$indexStart = 0
# calculate word frequency and mark for inclusion in Index
Set Selection 1, 0
While Find Next '\w{3,}', 'E-W'
$word = Read Selection
$word = Cast to String $word
$frequency{$word} += 1
Menu ':Insert:Index:Index'
Select End
End
Find Next '\Z', 'E'
# insert index
Type Text "\n\n"
$indexStart = Selection Location
Menu ':Insert:Index:Insert Index...'
Press Button 'Insert'
# insert frequency information
Set Selection $indexStart, 0
While Find Next '(\w+)(?=\t)', 'E-W$'
Select End
$word = $1
$count = $frequency{$word}
Type Text ' '
Insert Text "($count)"
Menu ':Format:Italic'
Select End
End
Here is another attempt.
You can change the behaviour of the macro by modifyingnear the beginning of the macro.
Perhaps the definition of word used in this macro does not meet your needs. If so, please let us know.
This macro does not always work fine:
- It may not work properly for a document containing section notes ("Place: End of Section" in Endnote style).
- Whole note text is treated as if it belongs to a page having the corresponding note reference even if the latter half of the note text is situated in the next page.Formatted macro file:
http://www2.odn.ne.jp/alt-quinon/files/ ... st_nwm.zip
On this occasion, I'd like to repeat my past request for new macro commands. I think they would make it easy to write this kind of macros. Thanks.
$sel.location.pageNumber
$sel.location.lineNumber
$sel.location.paragraphNumber
$sel.insertIndex [topic [,subtopic]]
$shortestWordLength = 3
$prefix = Cast to String '- '
$suffix = Cast to String '.'
### Complete List Macro ###
# A new macro, let's call it Complete List, where the macro will be able to:
# a. list every word (case sensitive)
# b. list the number of frequency next to the word (italic style)
# c. list the page number next to the frequency number (plain style)
# If there are more than one frequency in a given page, let the number of frequency show and the page number to follow, for example:
# - California, 6–4,8,9,9,11,12.
# The dash between the frequency and the page number is "n-dash", so the processor won't hyphenate.
# Known problems
# - This macro may not work properly for a document containing section notes ("Place: End of Section" in Endnote style).
# - Whole note text is treated as if it belongs to a page having the corresponding note reference even if the latter half of the note text is situated in the next page.
Require Pro Version 1.2
if $doc == undefined
exit # exit silently if there is no open doucment
$start = Date.now
$text = $doc.text
$pages = Array.new
$i = 1
While Select Page $i
$page = $doc.textSelection
$pages.appendValue $page
$i += 1
Select Start # deselect
$findExp = '(?=\b[\p{L}\'\’-]{' & $shortestWordLength
$findExp &= ',}\b)\p{L}(?:[\p{L}\'\’-]*\p{L})?'
$pageNumHash = $freqHash = Hash.new
$sepPageNum = Cast to String ","
$sepEntry = Cast to String ",\x20"
$p = 1
foreach $page in $pages
$pageText = Cast to String $page.subtext
$founds = $pageText.findAll $findExp, 'E-i' # PowerFind Pro and Case-Sensitive
foreach $found in $founds
$word = $found.subtext
$pageNum = $pageNumHash.valueForKey $word
if $pageNum == undefined
$pageNum = $p
else
$pageNum &= $sepPageNum & $p
$pageNumHash.setValueForKey $pageNum, $word
$freqHash{$word} += 1
$p += 1
$words = $pageNumHash.keys
$words.sort 'li' # l: localized (sort order chosen in Intl Pref pane and i: case-insensitive
$output = ''
$nDash = Text.newWithCharacter 0x2013
$LF = Text.newWithCharacter 0x000A
foreach $word in $words
$output &= $prefix
$output &= $word & $sepEntry
$c = $freqHash.valueForKey $word
if $c > 1
$output &= $c & $nDash
$output &= $pageNumHash.valueForKey $word
$output &= $suffix & $LF
New
Menu ':Format:Paragraph Alignment:Align Left'
$doc.clearAndDisableUndoHistory
Type Text $output
$numFound = Find All '[0-9]+(?=\x{2013})', 'E' # one or more Arabic digits followed by en-dash
if $numFound
$finish = Date.now
$elapsed = $finish.secondsSinceUnixEpoch - $start.secondsSinceUnixEpoch
exit "Finished in $elapsed seconds"
### end of macro ###
Wow! I have downloaded the macro and tried it on one of my files. It took 46 seconds to list a 30 page document, in an untitled new file, and it was awesome!
thanx a million.
Windsor
thanx a million.
Windsor
I discovered a bug in the macro: words followed by note references will be ignored. As I don't know how to remove the bug from the macro itself, I wrote another macro as a workaround.
This macro inserts (or removes) Zero-Width Joiner before all note references in the body so that Complete List macro recognizes words followed by a note reference properly. As ZWJ is a zero-width invisible character, the pagination of the document should remain the same but I noticed small differences in some cases. So please be attentive.
Sorry for the trouble.Formatted macro file:
http://www2.odn.ne.jp/alt-quinon/files/ ... es_nwm.zip
### ZERO WIDTH JOINER before Note References ###
# This macro insert or remove U+200D ZERO WIDTH JOINER before all note references in the document body. As this is a zero-width invisible character, the appearance of the document should remain the same.
# When you run this macro, you will be asked to choose which action you want the macro to do.
# Nothing will be inserted where U+200D is already present.
$joiner = Text.newWithCharacter 0x200D # ZERO WIDTH JOINER
exit # exit silently if no document is open
$text = $doc.text
$notes = $doc.allNotes
if ! $notes.count
exit 'No footnote/endnote found, exit...'
$message = 'Insert or Remove ZERO WIDTH JOINER before Note References'
$detail = 'Hit Stop Macro to cancel the operation'
$insert = 'Insert'
$remove = 'Remove'
$action = Prompt $message, $detail, $insert, $remove
foreach $note in reversed $notes
$range = $note.documentTextRange
$sel = TextSelection.newWithLocationAndLength $text, $range.location - 1, 1
if $action == $insert
if $sel.subtext != $joiner
$text.insertAtIndex $range.location, $joiner
else
if $sel.subtext == $joiner
$text.deleteInRange $sel.range
Kino: Thank you for the macro. However, when I used this last version, this is what the message said: The Macro "ZWJbeforeNoteReferences" has been completed. No footnote/endnote found, exit… and then I had to push the OK button.
Now. I sent the previous macro to my friend for a test drive, he said that the punctuation marks (in the Armenian) are not ignored, which, as a result, the words are chopped. See, for example, the word which? (in English) has the question mark at the end of the word, in Armenian, however, is in the word itself, like this: Ո՞րմէկը. As you can see, the question mark is after the first character. So, the macro should INCLUDE the Armenian punctuation marks, so that the words won't be split. Otherwise the first version is exactly how I need it to work, that is, when executing it from the macro's menu, a new file is being created and the list of the words are being made. But with the new editing, it should be able to keep the punctuation marks. Here are the marks:
ՙ
If you want copy and paste these characters for your convenience, if need be. And please use the CompleteList macro. The new one did not create a new file and did not create the word list.
Windsor
ՙ
Windsor
Sorry, I should have been clearer. "ZWJbeforeNoteReferences" is not a new version of the "Complete List" macro but an auxiliary macro which should be run before "Complete List" macro when the target document contains footnotes/endnotes. You don't need running it for documents not having footnotes/endnotes.Windsor wrote:However, when I used this last version, this is what the message said: The Macro "ZWJbeforeNoteReferences" has been completed. No footnote/endnote found, exit… and then I had to push the OK button.
I did not know that. The writing system of Armenian looks very interesting. Then, I replacedSee, for example, the word which? (in English) has the question mark at the end of the word, in Armenian, however, is in the word itself, like this: Ո՞րմէկը. As you can see, the question mark is after the first character. So, the macro should INCLUDE the Armenian punctuation marks, so that the words won't be split.
$findExp = '(?=\b[\p{L}\'\’\x{559}-\x{55F}-]{' & $shortestWordLength
$findExp &= ',}\b)\p{L}(?:[\p{L}\'\’\x{559}-\x{55F}-]*\p{L})?'
(I renamed the macro "Complete Word List" which I think more descriptive but you can give any name to it for it does not depend on any other macro.)
Kino:
Thank you for the attempt. I tried the latest version, and still it chopped the words that had the punctuation. When I checked your code, in this forum, I realized that there were two of the punctuation marks that were in the list (559 and 55f) and the rest were hard to understand for me. I checked the Unicode list of the Armenian font and I saw the following:
0559 for ՙ
055A for ՚
055B for ՛
055C for ՜
055E for ՞
055F for ՟
Could you try to include these codes in the macro, so that the words that will be having one of these punctuation marks won't be split?
By the way, I like the name Complete Word List. Let's keep it.
Thanks a million.
Windsor
0559 for ՙ
055A for ՚
055B for ՛
055C for ՜
055E for ՞
055F for ՟
Thanks a million.
Windsor
Sorry for the trouble. Please try this one.
I changed the find expression towhich seems to work.
'\x{559}-\x{55F}' in this and the older expressions stands for a character range from U+0559 and U+055F. And I don't understand why the older expression does not work. I should miss something obvious ;-(
$findExp = '(?=\b(?<c>\p{L}|[-\'\’\x{559}-\x{55F}]){' & $shortestWordLength
$findExp &= ',}\b)\p{L}(\g<c>*\p{L})?'
Kino:
Now we're talkin'!
Thanx a million.
Windsor
Now we're talkin'!
Thanx a million.
Windsor
This looks like a problem with our regex engine- I'll file a bug. Thanks and sorry for any confusion it caused.Kino wrote:'\x{559}-\x{55F}' in this and the older expressions stands for a character range from U+0559 and U+055F. And I don't understand why the older expression does not work. I should miss something obvious ;-(
Using macro commands newly available in Nisus Writer Pro 1.3, I rewrote the macro. Thanks to a proper command to get the page number (pageNumberAtIndex), it is not necessary any more to invent tricky code and the macro runs faster.
I changed the output format so that you will get
- actually, 9–20(4),37,44,45,50(2).
instead of
- actually, 9–20,20,20,20,37,44,45,50,50.
I don't know if you, Windsor, like it, though.
Also, this version distnguish words in note text by putting “n” after page number.
By changing the value of the variables at the beginning of the macro, you can customize the behaviour of the macro as you like.
A problem, though. Is it impossible to get table object without making a selection in a table cell actually? This makes the macro slow down if you run it on a document having many tables like Nisus Macro Reference.zrtf.If so, is it possible to make table command work with text selection objects in a future version so that $sel.table returns the corresponding table object for a text selection situated in a table cell? Thanks.
instead of
$where = $sel.text.documentContentType
if $where == 'table'
$doc.setSelection $sel
$where = $doc.tableSelection.table.enclosingText.documentContentType
### Complete Word List Macro (rev. 2) ###
# Written for Windsor.
# If there are more than one frequency in a given page, let the number of frequency show and the page number to follow, for example: - California, 6–4,8,9,9,11,12.
# The dash between the frequency and the page number is "n-dash" [$freqSep], so the processor won't hyphenate.
# Changes:
# - When the same word appears multiple times in the same page, it will be noted as pageNumber(numberOfCoccurences), e.g. 23(7), where “(“ and “)” are defined by $openingFreq and $closingFreq.
# - For a page number in note text, “n“ ($noteSuffix) will be appended to it, e.g. 23n.
# - Words in Comments, Headers and Footers are ignored.
$caseSensitive = true # set it to false if case-insensitive is preferable
$entrySep = Cast to String ', '
$freqSep = Cast to String '–' # en-dash
$pageNumSep = Cast to String ','
$noteSuffix = Cast to String 'n'
$openingFreq = Cast to String '('
$closingFreq = Cast to String ')'
$debugEnabled = false
Require Pro Version 1.3
Debug.setCodeProfilingEnabled $debugEnabled
if $shortestWordLength < 2
$findExp = '\b\p{L}(?:[-\'\x{2019}\x{559}-\x{55F}\p{L}]*\p{L})?\b'
else
$SWL = $shortestWordLength - 2
$findExp = '(?=\p{L}(?<w>[-\'\x{2019}\x{55A}-\x{55F}\p{L}]){' & $SWL
$findExp &= ',}\p{L})\b\p{L}(?:\g<w>*\p{L})?'
$sels = $doc.text.findAll $findExp, 'Ew', '-amn' # find in the main body and notes only
$data = Hash.new
foreach $sel in $sels
$word = $sel.substring
if $caseSensitive == false
$word = $word.textByLowercasing
if $data{$word} == undefined
$data{$word} = Hash.new
$pageNum = $sel.text.pageNumberAtIndex $sel.location
if $where != 'body'
$pageNum &= $noteSuffix
$data{$word}{$pageNum} += 1
$words = $data.keys
$words.sort 'li' # l: localized (sort order chosen in Intl Pref pane) and i: case-insensitive
$output = Array.new
$outputTemp = $prefix & $word
$outputTemp &= $entrySep
$c = 0
$pages = $data{$word}.keys
$pages.sort
$pageTemp = Array.new
$count = $data{$word}{$page}
$c += $count
if $count > 1
$page &= $openingFreq & $count
$page &= $closingFreq
$pageTemp.appendValue $page
if $c > 1
$outputTemp &= $c & $freqSep
$outputTemp &= $pageTemp.join($pageNumSep) & $suffix
$output.appendValue $outputTemp
$output = $output.join $LF
if $debugEnabled == true
$doc.setSelections $sels
$WordList = Document.newWithText $output
$WordList.clearAndDisableUndoHistory
$findFreq = '[0-9]+(?=\Q'
$findFreq &= $freqSep & '\E)'
$numFound = Find All $findFreq, 'E'
if $numFound
Select Document Start
That‘s a great and helpful macro. Now I wonder about this: The page as a „package size“ is of course very interesting for physical books. But for text analysis it is often more interesting to know whether a certain word appears within a package size you define yourself, f.e. within a paragraph, or within a chunk of text defined by a delimiting character.
Would it be difficult to adapt the macro in this way?.
I realize that the net result could be achieved by preparing the text itself: replacing all returns by soft returns, and all page beaks by returns. But I would not even know how to achieve the latter.
The easiest way is to modify the target document so that each package (defined by you) is a paragraph or a section. Then, replace pageNumberAtIndex at the 57th paragraph of the macro with paragraphNumberAtIndex or sectionNumberAtIndex. Which is more appropriate depends on the structure of the document. If it contains a table, you have to use sectionNumberAtIndex because, unfortunately, paragraphNumberAtIndex does not work properly for text in table cells. In NW Pro 1.3, if you copy a section break onto the replace field, you can replace a given string (e.g. two successive returns, a page break) with Section Break (Same Page) with “Replace Attributes” turned on. Or by using Replace All Breaks macro.js wrote:But for text analysis it is often more interesting to know whether a certain word appears within a package size you define yourself, f.e. within a paragraph, or within a chunk of text defined by a delimiting character.
Net result? 釣果? I'm not very sure if I understand what you mean but you can achieve it by…I realize that the net result could be achieved by preparing the text itself: replacing all returns by soft returns, and all page beaks by returns. But I would not even know how to achieve the latter.
Replace All '\n', '\x{2028}', 'E', '-am' # -am: in main body text only
Replace All '\f', '\n', 'E', '-am'
However, if your document is already logically split by page breaks, I think you would better replace page breaks with section breaks and use sectionNumberAtIndex.
The good news as far as I am concerned: The modification works perfectly well with paragraphs, thank you.
As for sections, I don’t not know: If I add a section break from the insert menu, and paste it into a find window (in Regex mode) what it actually inserts is \f, the same as a page break. (And by the way: I did not find \f in the Macro Manual … ) So I know now how to insert Page Breaks with a macro, but not how to insert sections breaks. Never mind. I don’t need to right now. I am perfectly happy with paragraph breaks. But to have your macro really do what I want, I lack a final step.
With that little modification I get a list of words with paragraph references. But I use other meaningful references. They consist in one word at the beginning of the paragraph. Let’s see I use
Anna at the beginning of paragraph 1
Judy at the beginning of paragraph 2
Emma at the beginning of paragraph 3
Now your macro tells me that such and such word can be found in 1 or in 3. But I would like it to tell me that it can be found under Anna or under Emma. How can this be done? I guess it would mean producing a hash like
1 -> Anna
2 -> Judy
3 -> Emma
And then those numbers should be replaced in the result of your macro by the corresponding names. Or is that a weird detour for somethin that can be done easier through an other method?
1 -> Anna
2 -> Judy
3 -> Emma
