special character keyboard shortcuts
Can I create NWP-specific keyboard shortcuts for special characters manually (by double-click) inserted from Character Palette, such as ž or ā?
Sebastian
NWP v 1.2.4
MacOS 10.7.5
NWP v 1.2.4
MacOS 10.7.5
Re: special character keyboard shortcuts
This is not currently possible to do directly, however, it is relatively simple to set up some macros for common characters. Here's how:
1. Create a new macro for the character you desire, it would look like:
2. Save the macro to your Macros folder (easy to do using the menu Macro > Save As Macro.
3. Go to the Menu Key preferences and assign the macro a shortcut.
One might accomplish this across all Cocoa applications (NWP included) by configuring your OSX Keyboard Bindings and/or keyboard layout, but I'm not an expert on that. You can read this page, but it's very complicated.
Type Text 'ž'3. Go to the Menu Key preferences and assign the macro a shortcut.
Sebastian -
you can customize your German keyboard the way the U.S. keyboard is Extended -
I did my "German Extended" keyboard with "Ukelele" from SIL.org -
http://scripts.sil.org/cms/scripts/page ... id=ukelele
It is easily done and then you can write whatever special characters needed -
as easily as writing French with German keyboard...
HE
HE
MacBook Pro i5
SSD 840/850 Pro
High Sierra 10.13.6
Nisus Writer Pro 3.4.1
SSD 840/850 Pro
High Sierra 10.13.6
Thanks Elbrecht, I was hoping you'd post, since you know much more about keyboard customization than I ever will!
keyboardmonster
martin,
where is the keyboard?!
@ Elbrecht
Elbrecht,
I'm thinking about using Ukelele but I'd like to know one thing first: Is it possible with Ukelele to disable the CAPS LOCK key? It's quite annoying hitting it accidently while typing fast and finding later that you've typed several lines in capitals.
- ninjagame
Elbrecht,
- ninjagame
Well -
if I understand your question - my SIL "Ukelele" done "German Extended" keyboard is located at:
"User" / Library / Keyboard Layouts / German Extended.keylayout
HE
HE
MacBook Pro i5
SSD 840/850 Pro
High Sierra 10.13.6
SSD 840/850 Pro
High Sierra 10.13.6
I guess -
but didn't work on "Caps Lock" myself - but "Ukelele" comes with "Tutorial" and "PDF-Manual" plus "Online Help". Give it a try - I started with duplicating "U.S. Extended" and added "German" specials to get my "German Extended" running...
HE
HE
MacBook Pro i5
SSD 840/850 Pro
High Sierra 10.13.6
SSD 840/850 Pro
High Sierra 10.13.6
I see, and I'll give it a try. Nice project for the weekend.
- ninjagame
- ninjagame
