character options keyboard shortcut
shob72
Post by shob72 »
In addition to the existing character options keyboard shortcuts, like ⌘b for «bold», can I create NWP-specific new ones, e.g. for «superscript»?
Sebastian
NWP v 1.2.4
MacOS 10.7.5
Re: character options keyboard shortcut
Yes, you can. In Preferences=>Menu Keys:
Ruchama
Post by Ruchama »
sure. you can assign all menu commands with shortcuts through the preferences of nisus, in the Menu Keys pane.
shob72
Post by shob72 »
thank you
Sebastian
NWP v 1.2.4
MacOS 10.7.5
Don't forget you can use multi-character shortcuts in NWP. I have text colours set that way: Cmd-RR = red, Cmd-BB = black, Cmd-BL = blue, etc. It's often easier than having to set up gymnastic multi-modifiers, e.g. Shift-Ctrl-Cmd and a single letter.
