Hello,
How can I increase the space between the text of the footnotes and the dividing line?
Thanks,
Roy
Spacing dividing line & text in footnotes
- picture
- Picture 1.png (7.11 KiB) Viewed 195751 times
Re: Spacing dividing line & text in footnotes
In Style Sheet, Select 'Footnote' under Note Styles and increase the Gutter Height by overwriting the default number:
- GutterHeight.png (13.67 KiB) Viewed 195746 times
Changing the gutter increases the space between the footnote itself and the rest of the text. I want to change the space within the foot note so the text inside of it will be further down from the dividing line (see attached pic).
- Picture 1.png (8.91 KiB) Viewed 195739 times
In that case, you have to adjust 'Align in Gutter' pop-up. Try 'Top' or 'Center'.
