I'm using NWE 1.1 right now. I've noticed that the palletes from the tool drawer don't look like aqua "windoids" when they are torn off into floating windows. They look like they have sort of a Windows XP chrome motif instead.
Did a previous version of NWE have more of an aqua look to these palletes or have they always been this way?
Now, I really should get back to what I'm working on, instead of geeking out over interface anomolies...
In addition to what Mark said, I would add that we changed the floating palettes so that they are the same as the palettes you can put into your tooldrawer. Before they did not act quite the same way; floating palettes had fewer options. For example, now you can collapse the palette titlebars, they attach to eachother and snap to the edges of the screen, none of which was available in 1.0.
