Borders?
Borders?
Is there a way of drawing a horizontal line across a page, e.g. after paragraph or a list? Borders only seem to work on Tables and around the *whole* page.
- greenmorpher
Re: Borders?
Hello Andreas
No there isn't. Nisus Writer on classic, the first -- and for a long, long time, only -- WP on Mac (or anything else) to have graphics capabilities, has not yet regained that feature in OS X.
The work-around is to load one of the cheap (well reasonably cheap) graphics programs for OS X, draw your lines in that, then paste them into NWPro.
If you use one of the graphics editors which shares LinkBack with NW, you will be able to edit that graphic feature in its original application simply by double clicking on it in NWPro.
Cheers, Geoff
"Type & Layout: Are you communicating or just making pretty shapes" -- the secrets of how type can help you to sell or influence, now at the new low price of $29.95. See the book at http://www.worsleypress.com or Amazon.
Cheers, Geoff
Re: Borders?
You could, as a workaround, create a single-line table and cancel all borders but a horizontal one, make the spacing minimal and get the line you want.
Is there a chance to get graphics tools back into nisus? is it planned at all?? please..
Re: Borders?
Or put in a blank line, put a tab at the right margin, double click the tab set it to "right tab" and choose "Underline" as the leader ... you have a range of line formats to choose from. Then simply type a tab character in that paragraph.
Re: Borders?
Thanks very much - which graphics apps support Linkback?
Re: Borders?
That does not underline the tab ared - just text and spaces are being underlined. And I couldn't find any line options. Are you talking about this underline button or is there a more detailed option elsewhere:xiamenese wrote:Or put in a blank line, put a tab at the right margin, double click the tab set it to "right tab" and choose "Underline" as the leader ... you have a range of line formats to choose from. Then simply type a tab character in that paragraph.
Re: Borders?
cool! learned something new today. thanks Mark!
Andreas- follow his instructions. it works!
Re: Borders?
I'd like to follow Mark's instruction but I don't know what he means by "leader". I'm on the Germany version and can't find anything that seems to correspond to that.
Re: Borders?
OK - it took some searching but I found it. Thanks Mark, it does work now!
Re: Borders?
After placing the leader tab (Führungszeichen), double click on the tab icon in the tab ruler. You will get a dialog which looks like this:
- Tabulato.png (86.16 KiB) Viewed 14627 times
Re: Borders?
Thanks Hamid, I hadn't realised I could change that style *after* setting the tab.
- greenmorpher
Re: Borders?
For goodness sake, yes! Don't worry about the rest of us, Hamid, we'll catch up!
My apologies, Andreas, I meant to add the link to the hidden list. You need to go to the search for Linkback on the Nisus home page, and it will take you to Google and the top entry will be: http://linkback.nisus.com/
And there you will find out all about LinkBack.
I can't udnerstand why it is not promoted on the home page, but I can't se it there.
Cheers, Geoff
Cheers, Geoff
- greenmorpher
Re: Borders?
Oh, I forgot to mention. Mark and Hamid pointed out the Nisus line for a tab leader. Did someone else suggest using underscores or have the painkillers I took for my twisted ankle had more effect on my head than I think?
Anyway, I once did that. Most embarrassing -- different fonts have different length underscores. What looked like a nice line in one font, changed to a dashed line in another.
But the Nisus lines are proper lines.
Cheers, Geoff
Cheers, Geoff
Re: Borders?
Thanks very much. I think either tables or leader tabs will do the job for me.
