Could we get a simple example or two for the use of objects?
The new additions to the macro language seem to be very promising, particularly the use of Objects. But for some of us hobby programmers it would certainly be easier to understand how that works with some examples. May I suggest to furnish us a simple macro like how to get multiple selections of a text into a new document, each on a line?
Sure, the macro reference is still a bit light on examples. Here's a macro that takes all selected bits of text and places them in a new document:
Another example that collects an array of all font families in use in a document's main body:
$texts = $doc.selectedSubtexts
New
ForEach $text in $texts
Type Attributed Text $text
Type Text “\n”
End
# use a hash to efficiently coalesce duplicates as we go
$usedNameMap = Hash.new
$text = $doc.text
$charIndex = 0
$limit = $text.length
# inspect the attributes applied to every character in the text
While $charIndex < $limit
$attributes = $text.displayAttributesAtIndex($charIndex)
$fontName = $attributes.fontFamilyName
# if the font was defined, mark it as used
If Defined $fontName
$usedNameMap{$fontName} = 1
End
# move to the next area that has different attributes
$range = $text.rangeOfDisplayAttributesAtIndex($charIndex)
$charIndex = $range.bound
End
# turn the hash into a proper array for display
$fontNames = $usedNameMap.keys
Prompt $fontNames
