Macro executes only on using a second time
js
Post by js »
I have a macro the filters texts, arranges it, pastes it in a new document and adds colors there according to certain criteria.
This macro works just fine, but after opening Nisus, it does not fully execute the first time. It pastes the text in the new doc, but then does not continue adding the colors. Use it at second time and from then on it works right to the end. Is it possible to put a pause after the first stage? Would that help?
I've not seen this- could you send us the macro?
