Paste command interrupts macro
js
Post by js »
In a macro I have a paste command.
This can halt the macro with a choice:
"Add Pasted styles" or "Use existing Styles"
and the macro waits for user input.
Can this user input be given in the Macro itself?
PS I think this is the one and single feature of Nisus which I find right out annoying: That first time pasting is interrupted by this choice. It may depend on the type of work you do and the type of documents you use. If I could choose in the Preferences that Pasting always means "Use existing Styles" except if a press the option key or something then my life as a Nisus user would change. It would spare me hundreds or thousands of annoying interruptions of my work. Anybody feel the same?
At this time there is no way for the macro to decide how to deal with conflicting styles, sorry.
