What is the perl command for moving the cursor one space to the left and one space to the right?
Thnx
perl language for moving the cursor
Perl itself cannot change the selection. You'll have to use a Nisus macro language command. Here's how to move the cursor one space to the right:
If you have some Perl code that needs to calculate a more complicated selection location, just use the fact that variable values transfer across embedded Perl blocks:
$location = Selection Location
$location += 1 # add one to the location
Set Selection Location $locationCode: Select all
Begin Perl
$location = ($location * 2) + 5;
End
Set Selection Location $location-
Thomas C. Wolfe
thanks, and...
and I suppose that
$location=Selection Location
location -=1
Set Location Location $location
means move cursor one space to the left?
location -=1
Thomas C. Wolfe
exactly!
Thanks for this. Experiment is what I shall do!
