Feature request: Rotated text
dmw
Post by dmw »
Any chance we'll see the ability to rotate text in the near future? This is especially useful in tables with long column headings
rmark
Post by rmark »
Rotating text in a table is already on the official "to do" list. However, it's hardly an easy task so it should take some time.
Write On!
Mark Hurvitz
Nisus Software Inc.
ptram
Post by ptram »
Not a solution, but a trick that might be useful: grab a picture out of the title text by using Shift-Ctrl-Cmd-4, and paste it into a new document in Preview (or a drawing application). Rotate it, and use the above shortcut to grab a new picture. Paste it into a side cell, and it will look like rotated text.
Paolo
Elbrecht
Post by Elbrecht »
Well -
I definitely would prefer dropping a rotated PDF - we are on OX, aren't we? You can Save as PDF in all apps and Crop and Rotate in Preview - Insert to Nisus Pro then. PDFs are resolution independent, so will print at best anywhere.
BTW rotated text entered in Word gets misplaced in Nisus Pro, too...
HE
MacBook Pro i9
Tahoe 26.7
NWP 3.4.1
