Hyphenation
ngazidja
Hyphenation
Post by ngazidja »
Any--one else having prob---lems with mul---ti--ple hy---phens show---ing up, not on----ly at the ends of lines but of----ten right in the mid--dle of words?
It's a pain. Of course I could always turn hy----phen--a----tion off.
greenmorpher
Post by greenmorpher »
I normally have it off, but I just did a couple of tests and no problems here.
Cheers, Geoff
mrennie
Post by mrennie »
I experienced a couple of problems with hyphens showing up in spaces following a paragraph (with a "space after" setting). I e-mailed the document to Nisus and was told that there is an issue with Apple's hyphenation engine; there's nothing Nisus can do except wait for Apple to fix it.
greenmorpher
Gawd -- and Apple os producing a junior pay layout program. Time they ripped themselves into gear on the basics. Another one someone raised a while back was an alighment problem with bullet points.
Cheers, Geoff
