Nisus RTF and Open office ODT
K-9
Post by K-9 »
Just curious. can nisus writer read the open office or neooffice ODT file format? and can they read the nisus writer format rtf?
I have all macs in the house and office, but I am also exploring Linux and was wondering if i can transfer files from the mac to the linux laptop and linux laptop back to the mac?
Since the laptop has neooffice on it I was wondering how compatible it was for the exchange.
I cannot try it at the moment - the Thinkpad won't be here till Tuesday.
Thank you.
MacSailor
Post by MacSailor »
I believe that both Open Office and Neooffice can read rtf files created by Nisus, but I do not believe that NWE/NWP can open odt files at all.
Peter Edwardsson
K-9
Post by K-9 »
Ok - there are probably other ways or formats to save in OO or Neo that wil enable nisus to read it - I will have to check when i get Mint linux loaded on the laptop.
Thank you.
greenmorpher
Post by greenmorpher »
Doggles
Save from OO as .rtf or .doc and NWE/Pro can open those documents.
Cheers, Geoff
K-9
Post by K-9 »
Ok - I thought I had seen other formats in the save or save as in neooffice when i used to use it.
Thank so much!
arf!
