Many problems with equations created in LaTeXiT and dragged to NWP document.
1. Linkback not working properly. It seems that I need to double click the equation in NWP in an special area in order to open it in LaTeXiT. Otherwise, I just get the image panel. Sometimes, it works, sometimes it does not. I notice that it works when a hand cursor shows above the equation. I can't find a pattern though.
2. Open NWP rtf with Microsoft Word -> resolution of equations in Word is really bad. Save rtf in NWP to doc format -> Open doc file in Microsoft Word -> resolution of equations really bad
Using a MacBook Pro
Please Help
LaTeXiT and NWP - Equations to Microsoft Word
nestorCardozo
