I have just finished a 400 page document in NisusWriter Classic
(when I began writing it, NW Pro was not yet available). Now,
with NW Pro and it's Glossaries features, I converted it to
NW Pro rtf format, using Kino's Apple script.
The formatting is simple: one font, and the same size throughout
the whole document, seven or eight paragraph styles, some italics,
bolds and bold smallcaps, the same header and footer, both with a
small logo.
The conversion itself worked quite well (only the bold small caps
has been lost).
But the performance of NW Pro working with the new document
is not very appealing.
Opening the document from within the application's Open
dialog, took 38 sceconds!!! NW Classic opened it in 2 seconds.
Working with the NW Pro document is a nightmare, as long as
the auto-save option is enabled, because it takes several seconds
to save the document.
I hope that a solution may be found in a further update of NW Pro.
G. Beurlen(':?')
Rio de Janeiro Brazil
