Setting The Style For Unstyled Paragraphs
WolfUK
Post by WolfUK »
To help me evaluate Nisus Writer Pro I imported a pretty hefty document that I have been working on. It came across pretty well but since it was a Pages document that I exported to RTF and then opened it lost all of the styles that I had defined. This is not a major problem but it would save me a lot of time if I only had to create new styles for headings and a few other items and was then able to designate every other paragraph without a style as being my 'Body' style.
Is this sort of thing possible?
Simon Wolf
I'm going to guess what you want is possible, but I'm not sure exactly what you're after. What criteria do you want to use for selecting paragraphs that need to have styles applied? You just want to select all paragraphs without any paragraph style and then apply your Body style?
WolfUK
Post by WolfUK »
Yes, exactly right, I was to select all paragraphs without a paragraph style and apply my Body style.
Simon Wolf
Hi Simon, I'm sorry to say I spoke too soon. There's no way to select all the text in your document that has no paragraph style applied. Does the text you want to apply your style to really have no style applied, or just some generic style like Normal that you don't care for?
WolfUK
Post by WolfUK »
Hi Martin,
There was no style selected at all (as far as I can tell ... maybe because I didn't have a style called Normal nothing was displayed). Anyway, don't worry too much because as I worked through the document checking that everything had come in properly and that it was all laid out properly I added the paragraph styles.
Now, if there was better AppleScript support ... :wink:
Simon Wolf
Kino
Re: Setting The Style For Unstyled Paragraphs
Post by Kino »
Thanks to the great improvement of the Nisus Macro language, now we can write such a macro. I'm not using Pages but sometimes I need to do the same thing, for example, when formatting an etext.
$defaultParagraphStyleName = 'Normal'  # Put an appropriate paragraph style name between the single quotes
Require Pro Version 1.3
if $doc == undefined
	exit  # exit silently
$paras = $doc.paragraphStyles
$defaultParagraphStyle = undefined
foreach $para in $paras
	if $para.name == $defaultParagraphStyleName
		$defaultParagraphStyle = $para
		Break
if $defaultParagraphStyle == undefined
	exit "You have to create or import \"$defaultParagraphStyleName\" paraagraph style before running this macro, exiting..."
$sels = $doc.text.findAll '^\p{Any}', 'E', '-am'  # in the main document body only
foreach $i, $sel in reversed $sels
	if $sel.text.documentContentType != 'body'  # then, $sel is in a table
		$sels.removeValueAtIndex $i
	else
		$attr = $sel.text.attributesAtIndex $sel.location
		if $attr.paragraphStyle != undefined  # then, this paragraph has a style
if $sels.count
	Push Target Selection $sels
		$defaultParagraphStyle.apply
	Pop Target Selection
else
	exit 'There is no paragraph not having a paragraph style, exiting...'
Hi Simon, I don't know if this is what fits your case, but if I have an imported file in which I'm going to have to style everything, what I do is immediately select all and apply my body style. Only after that do I go down changing the headings and subheadings and anything else that needs it to what I want.
Too late for this time, I guess, and maybe Kino's macro would suit you better, but that has always been my approach.
Groucho
Post by Groucho »
Simon said:
...It came across pretty well but since it was a Pages document that I exported to RTF and then opened it lost all of the styles that I had defined...
Hi, Simon. Have you tried exporting the file into .doc from Pages and opening it in NWPro? I seldom use Pages, yet it seems to me it is peculiar at dropping styles while preserving formatting.
Cheers, Henry.
