As I'm no programmer, I need help writing a macro. Some of my styles do not translate well when opening an rtf in Word, so I would like to create a Save for Word macro that does the following...
- Finds all of one style and replaces with another (if no style instance found, ignore and move to next command)
Finds all of another style and replaces with another (once again, if no style instance found, ignore and move to next command)
Turns off Allow Hyphenation
Saves a document as original filename without extension with (for Word) appended
- Find All Paragraph Style H1 Sans Bold xS and Change All to Word - H1 Sans Bold (if none, ignore and move to next command)
Find All Paragraph Style H1 Serif Bold xS and Change All to Word - H1 Serif Bold (if none, ignore and move to next command)
Turn off Allow Hyphenation (if already off, ignore)
Save in Document Manager with original filename with “(for Word)” appended at end
Thanks,
Scott
