Hi
Does anyone successes in using Linkback technology from NovaMind to NWX ?
Despite Novamind's help describes the way to use the Linkback technology:
"Select any branch or branches on your Mind Map, and press Command+C (copy). In your other LinkBack enabled application, paste the NovaMind Mind Map. No matter what you select, the whole Mind Map will be copied and inserted in the other application"
I'm not able to obtain any result: whatever the branch I copy, I only copy the text of the branch, not the whole map
Any help is appreciated.
Regards
Philippe
Novamind and linkback technology
philippe99
