I just switched to a new Mac. Thanks to the Migration Assistant almost all applications work on the new Mac like they did on the old. One of the few exceptions is NWP. When starting the application, the following message appears: "Your settings could not be loaded. Your settings could not be saved [etc.; see attachment].
Replacing the settings on the new computer with those on the old one didn't solve the problem. How can I get out of this?
"Your settings could not be loaded / saved"
- Screenshot 2025-01-13 at 14.18.47.png (40.49 KiB) Viewed 56078 times
Re: "Your settings could not be loaded / saved"
Hello,
I have to say that in all my years of using Macs, I have never used Migration Assistant to move everything onto a new computer; I do it by hand, so I can review my apps and not transfer ones I no longer use for whatever reason.
When it comes to NWP, after years of having to set it up to find the Document Manager, Shortcuts, macros etc., I now put all of that in a "Nisus Documents" folder on iCloud and set NWP on any machine find those settings there.
