[SOLVED] Printing comments
NisusUser
Post by NisusUser »
(Running NWP 3.4.1. beta 1 on Mac Sonoma 14.2.1)
Hi, everybody,
I found this old thread (last comment from 2010) about this: viewtopic.php?t=3697. It says there is no built-in way to print comments. I am almost sure I've printed comments from NWP before, though. And I don't think I did it with a macro.
When I press Cmd-P to print, the "Print Comments" box is already selected in the Print dialog. And the preview of what will print looks as if the comments will be printed. But when I print (to PDF), the comments are not there.
Print dialog
Print dialog
Print Comments.png (144.51 KiB) Viewed 17128 times
SOLUTION: I found my trial and error that all I have to do is deselect (untick) the "Print Comments" option and the re-select it (tick it), and the comments now print. I'm a happy camper.
I'm posting this here just in case some soul comes looking for a solution like I did.
