small UI-interface bug "add style from the pasted text to the document or use existing styles?
MathiasF
Post by MathiasF »
There is a useful feature when copy pasting: the check of which style to use.
However sometimes, this check pops up, when there is nothing to check.
When you redefine the style in a given document (using "Format", "Paragraphe style", "Redefine style from selection"), copy paste generates - within the same document for a text with a modified style - a questioning asking to choose between the style of the initial and final document. But there is only one document, so the message is irrelevant.
Cheers!
simple example attached:
copy me.rtf
trivial example with a modified style
(19.92 KiB) Downloaded 398 times
