I have some hyperlinks in a fairly simple document. When I save as PDF, the links don't look blue/underlined any more, but are black/underlined and don't function as links.
Any help? Help!
TIA,
Sean
Links in PDF not working
I believe midwinter is right. There are very few apps that allow you to preserve links when making PDFs. As far as I know, all of them are made by Adobe. I may of course be wrong (I frequently am), but at any rate NWE doesn't do it.
However, there's no reason the PDF couldn't keep the blue underlined look. I personally don't care for that (I hate seeing it in PDFs made from Word documents), but it could be an adjustable feature.
Ryan
www.r-blog.com
www.r-blog.com
OmniGraffle supports exporting multi-page PDFs with internal links and URLs... you guys are co-operating on LinkBack, maybe they could help you out there with some code!rmark wrote:You need the full version of Adobe Acrobat (not Reader) in order to have clickable links in a PDF. Perhaps a few other applications do that, but, Nisus Writer Express
![Wink ;)](./images/smilies/icon_wink.gif)
