Ventura and proplem opening documents from Finder
JudyGBee
Post by JudyGBee »
Since I upgraded to Ventura (13.4.1) I am unable to open a document from the finder window using Option-Shift and selecting Nisus Writer Pro in the drop-down menu.The program is already open and in the dock. Is there a "fix" for this? Do I need to uninstall the program and reinstall?
Judy Brown
Re: Ventura and proplem opening documents from Finder
Never used Opt-Shift for this; Ctrl-click (Right-click) brings the "Open With…" menu.
I spoke with Judy about this over email and a simple restart cleared the problem up, so it was likely some temporarily muddled bits in the Finder or macOS.
