Export to DOCX Error
loulesko
Post by loulesko »
Hi there,
I'm getting the error below when trying to export to DOCX on Macbook Pro M1. I've restarted, and reinstalled NWP. I do not have Rosetta, but Libre Office says they're Apple Silicon compatible.
Many thanks,
Lou
Screen Shot 2023-03-25 at 10.13.17 AM.png (45.6 KiB) Viewed 6963 times
Re: Export to DOCX Error
The LibreOffice-based converter inside Nisus Writer Pro is not Apple Silicon native and does require Rosetta on Mac with an M1/M2/etc chip. You should install Rosetta to import/export DOCX files with Nisus Writer, if you want higher fidelity for advanced content. If you aren't picky about fidelity/content, you can set Nisus Writer to use macOS for DOCX conversions.
loulesko
Post by loulesko »
Hi Martin,
First, didn't know there was a Mac option for the conversion. Very cool. But, sadly, even with that changed and a restart, I'm still getting the same error.
Thanks
Lou
