Finding SHORTEST Text
waltzmn
Post by waltzmn »
I feel as if I ought to know this, but I just can't make it work.
I have a list of bibliographic references that I need to clean up. Every entry has an abbreviation at the beginning, followed by a colon and space, then the actual entry. Here are three example lines:
Chambers: E. K. Chambers, _English Literature at the Close of the Middle Ages_, Oxford, 1945, 1947
Chaucer/Benson: Larry D. Benson, general editor, _The Riverside Chaucer_, third edition, Houghton Mifflin, 1987
Dobson/Taylor: R. B. Dobson and J. Taylor, _Rymes of Robyn Hood: An Introduction to the English Outlaw_, University of Pittsburg Press, 1976
What I want to eliminate is everything up to the first colon (the parts shown in bold), leaving the rest. So the above should become
So what tried to do is change
\n[^\n\f]+\: +
that is, (return)(any text)(colon)(space)(1+)
to just plain
\n
that is, (return).
This of course works for the first two lines, but the third line comes back as
It took all text to the last colon in the line, not the first colon.
How do I get the shortest match, not the longest?
Re: Finding SHORTEST Text
"+" gives a 'greedy' repetition
"+?" gives the shortest.
By the way in your expression you can just use a position match rather than 'replacing' the return:
^[^\n\f]+?\: +
PS: If you use the Find box, the menus have these repeaters listed :wink:
waltzmn
Post by waltzmn »
Thank you!
Actually, I did use the Find box; I can't remember that "[^\n\f]" part. :) But I didn't know what I should be looking for. :wink:
Again, thank you.
