hiding specific numbers
Les
Post by Les »
Does Nisus have a way to hide specific numbers on blank pages only?
Re: hiding specific numbers
I'm trying to think what you mean by "specific" numbers. I can think of two things.
1. If you want to hide page numbers (in the header/footer) on blank pages, you would probably have to make those pages a separate section. Then you can either have a different header/footer on those pages, or have hidden header/footers in that section.
Of course if your blank pages have no header/footer, than you can just skip them altogether :?
2. If you are talking about some specfic text on an otherwise blank page (like a "secret" code, which can be searched for, but does not print) then the main idea I can think of is to use a white text color. Nisus Classic used to allow hidden text, but NWP does not have this.
Other approaches might use textboxes, or perhaps comments.
