Page number stops between sections
rabbijacobs
Post by rabbijacobs »
I'm working on a long book.
I'm not sure why, but page numbering in the footers stops between sections.
I'm using Nisus Writer Pro 3.3.
Any ideas?
Re: Page number stops between sections
Check your section settings (in the palette). Most likely your later section is set to have "Different Footers". Either uncheck this, to give both sections the same footer, or add the page number to the footer of the later section.
