Strange behavior of fonts: defaulting to Black
Simeon
Post by Simeon »
Hello friends,
By default we use the font Iowan Old Style, set to Roman. In the past couple of weeks we have seen strange behavior where we change to italic, then change our minds, and un-italicise the phrase. When this is done, the font changes to the "black" font weight. There are also other instances of the "black" weight showing up. For instance, when copying from Nisus to Mac Mail, selecting a paragraph formatted Iowan Old Style Roman, and pasting it into mail, it becomes the Black weight.
Do you have an idea of a cause for this, and a solution?
We have Mac OS 11.5.2 and Nisus version 3.2.1.
Thanking you in advance for your sagely help.
Brother Simeon
Light of the Spirit Monastery
ocoy.org
lightofthespiritpress.com
Elbrecht
Re: Strange behavior of fonts: defaulting to Black
Post by Elbrecht »
Hi Simeon –
I am still running High Sierra and don't own Iowan Old Style – so I am of no help to you, sorry. But if you do not need Black for your job, I would try to Delete or Deactivate the Black variants in Font Book – may that does the trick for you!
Good luck
HE
MacBook Pro i5
SSD 840/850 Pro
High Sierra 10.13.6
Nisus Writer Pro 3.4.1
Simeon
Post by Simeon »
Thank you :), Elbrecht, this has solved the problem. The source of the problem is still a mystery, but with solution it doesn't matter.
Brother Simeon
ocoy.org
