Unable to Update Nisus Thesaurus v1.2 to v1.2.2
alvarnell
Post by alvarnell »
I'm still running Nisus Thesaurus v1.2 in macOS Catalina and noted that v1.2.2 has been out since last December, but when I select "Check For Updates..." from the Nisus Thesaurus menu it says "No updates were found".
Screen Shot 2021-04-25 at 7.52.07 PM.png (161.04 KiB) Viewed 155130 times
Re: Unable to Update Nisus Thesaurus v1.2 to v1.2.2
Unless you have a new Mac with Apple Silicon there's no real difference between Nisus Thesaurus version 1.2 and 1.2.2. However, if you really want the latest version you can download it manually here:
https://nisus.com/Thesaurus/download.php
