Hello
I'm using Nisus Writer 5.xxx and the macro language.
I've a small question:
How can I get the number of replaced expressions replaced with the 'search and replace' function (s&r). The s&r function displays the number of found and replaced expressions in a message box. How can I get this number. I'm using a macro and I need this value to control the macro flow.
Or is there an other possibility to count the number of the same expression in one paragraph.
Thanks for your help.
Count the number of replaced expressions
rmark
There is a command in Nisus Programming Dialect called "NumFound"
For example, the three line macro:
Find All "^.+" "g"
Clipboard="There are "=NumFound+" Paragraphs in this document"
:1 '\CC'
will display the number found on the Clipboard.
Try that.
Find All "^.+" "g"
:1 '\CC'
Try that.
Write On!
Mark Hurvitz
Nisus Software Inc.
Mark Hurvitz
Nisus Software Inc.
