Macro Syntax Coloring macro(s)
Since I was asked about this, I'm posting here the macros that I use for syntax coloring in my macros. They require the use of appropriately named styles in the document.
Macro Syntax Coloring.zip
(7.32 KiB) Downloaded 826 times
B.Otter
Re: Macro Syntax Coloring macro(s)
Post by B.Otter »
phspaelti wrote: ↑2021-02-17 20:27:05 Since I was asked about this, I'm posting here the macros that I use for syntax coloring in my macros. They require the use of appropriately named styles in the document.
Nice.
Actually, I should put an important warning here.
This macro somewhat crudely obliterates prior formatting in the file. This will be a serious problem if your macro uses formatted text strings or attribute sensitive Find and Replace. So please use it responsibly :D
