Thesaurus pane doesn't show
gvnd
Post by gvnd »
I downloaded and installed Nisus Thesaurus 1.2.1 a few days ago.
The app displays the dictionary ok, but for some reason the thesaurus section is missing. I've opened the app directly from the Applications folder and accessed it from Services in a couple of apps like Mail and TextEdit, but I get the same result. Dragging on the small dot between the Search and Definition boxes didn't help either.
Not sure if it's a bug, something I've missed or some other issue, but I'd like to get it working properly. Any suggestions?
Thanks
Mac Mini 2014, Mojave OS 10.14.6
Screenshot Nisus Thesaurus.png (55.71 KiB) Viewed 111041 times
Re: Thesaurus pane doesn't show
You have to drag down the dot between the search box and the definition box:
gvnd
Post by gvnd »
Thanks for your reply. I tried that but nothing happens. When placed over the dot, the cursor changes to a horizontal line with a down-arrow (as it should). When I click and drag it downwards the cursor then changes to a horizontal line with an up-arrow, but there is no movement or change to the window, only the cursor moves down. I tried cmd-click, opt-click and ctrl-click drag as well.
I uninstalled it, redownloaded a new file and installed but that didn't help either.
That's very strange. You should be able to click and drag the resizer knob that Hamid pointed out. It's a standard macOS system control.
You could try resetting Nisus Thesaurus on your Mac, to ensure there's no damaged settings that might be interfering. Here's how to completely reset Thesaurus:
1. Quit Thesaurus if it is running.
2. Run the following Terminal command:
defaults delete com.nisus.NisusThesaurus
3. Delete Nisus Thesaurus's sandbox folder. You can do that in the Finder by trashing the folder with this path:
~/Library/Containers/com.nisus.NisusThesaurus
To be completely thorough you should now reboot your Mac to ensure system caches are cleared, before you relaunch Thesaurus.
gvnd
Post by gvnd »
Did that and everything is set back to default but no change unfortunately. Have added a screen recording ...
https://tinyurl.com/y9e4amgd
It is true, the knob is quite slippery; anyway try this:
Quit Nisus Thesaurus if it is running. Then, from your Home Library/Containers/com.nisus.NisusThesaurus/Data/Library/Saved Application State/com.nisus.NisusThesaurus.savedState (Folder), delete the files:
data.data
window_1.data
window_2.data
windows.plist
Launch Nisus Thesaurus.
This should restore the setting.
gvnd
Post by gvnd »
I got as far as...
~Library/Containers/com.nisus.NisusThesaurus/Data/Library/Saved Application State/
After that there was no com.nisus.NisusThesaurus.savedState folder, or any of the 4 files you listed. It was an empty folder. Anyway, I don't think it's a corrupted file(s) because I've uninstalled Thesaurus a couple of times (using AppCleaner), restarted and reinstalled. A corrupted file should not persist after each reinstall.
Thanks for the updates, and I'm sorry nothing worked for you. After testing this myself it appears to be a problem that's specific to macOS 10.14 Mojave, and perhaps other older system versions. The problem does not occur on 10.15 Catalina or later.
I think the best practical advice is to simply revert to an older version of Nisus Thesaurus. If you're running on 10.14 Mojave then you have no need for the Apple Silicon support that was added in Nisus Thesaurus version 1.2.1. Nisus Thesaurus version 1.2 will suffice as there are no other new features.
gvnd
Post by gvnd »
Thanks for looking into it and for the link. Ver 1.2 works fine on my older system so I'll stick with that. :)
