Finding italics
Victorsteelballs
Finding italics
Post by Victorsteelballs »
I need to locate all of the occurrences of italics is document. How do I do it?
TIA
Re: Finding italics
Hello Victor: Nisus Writer Pro has a variety of ways to find all italic text. You might learn more by reading our FAQ on how to search for formatted text. However, here are a few quick ways to find all italic text in your document:
Find Italic Text Using the Formatting Examiner:
1. Place the insertion point (caret) in any existing italic text.
2. Show the Formatting Examiner palette.
3. From the listed formatting, under "Displayed Formatting", select the entry for "Italic".
4. Click the gear icon button and choose a contextual menu search command like "Find All in New Window".
Find Italic Text Using the Find Panel:
Another method is to use Nisus Writer's find panel. You can combine formatting sensitive searches with PowerFind pattern matching.
1. Open the Find & Replace window.
2. Under "find what" click the gear icon button and choose the contextual menu Wild Card > AnyText.
→ That will insert the "AnyText" bubble into the find field.
3. Select the inserted "AnyText" bubble and apply italics (this will automatically checkmark the "formatting sensitive" option).
4. Click any of the Find buttons, eg: Find All.
Victorsteelballs
Re: Finding italics
Thank you, Martin. Worked like a charm!
