Are the NWE Sneak Peek LinkBack enabled?
If it is, how do I use it with other LinkBack enabled applications? Just curious.
Peter Edwardsson
MacBook Pro M1 | macOS Sequoia
Beta 1 of Nisus Writer Express 2.5 is LinkBack enabled. To use LinkBack you basically just paste content from other LinkBack applications inside Nisus Writer Express. When the original content is changed, the data inside your Express document will update automatically. You can also double-click the pasted data to open it in the application that created it.
To see some other LinkBack applications, or for more info, visit: http://www.linkbackproject.org/
