Aside from native Nisus Writer Pro macros using our custom macro language, you can also run macros containing Perl code. These can be separate perl script files, or chunks of perl code embedded in full Nisus Writer macros.
For more see Write Perl Scripts below, or the Macro Language Reference’s discussion of perl blocks.
| Previous Chapter The Nisus Writer Pro Macro Language |
<< index >> |
Next Chapter Write Perl Scripts |
