Nisus Writer Express 3.5.9 released
Locked
This update fixes a few key issues.
This update is free for all license holders of Nisus Writer Express version 3.
Requires Mac OS X 10.8.5 or later.
Get the Update:
You may download the new version from our website.
If you purchased through Nisus Software and nisus.com, you can update inside the app, via the menu Nisus Writer Express > Check For Updates.
If you purchased through Apple's Mac App Store (MAS), the update will be available there soon, once it clears review.
Changes:
• Fixed: possible crash when editing footnotes in Page View.
• Fixed: trackpads could sporadically trigger unwanted zooming resulting in very tiny zoom percentages, eg: zoom set to 2%.
• Fixed: should respect system scrolling preferences, regarding the behavior for clicks in the scrollbar area (paging vs jumping).
• Fixed: table columns should not artificially be restricted to a maximum width of 1000 points.
Locked
