Look-behind in macro
branner
Post by branner »
I have a two-level Number List. The level-1 items are numbered 1,2,3,4 and the level-2 sub-items are numbered a,b,c,d. There is a sample file attached.
I want to automatically add a sub-item "b" after each sub-item "a'. I can do this manually with Powerfind Pro, finding
(?<=a\.\t)(.+?)$
and replacing it with
\1\nNEW LEVEL-2 "b" here
The look-behind expression is able to recognize level-2 sub-items that begin with "a".
But when I construct a macro:
Find and Replace '(?<=a\.\t)(.+?)$', '\1\nNEW LEVEL-2 "b" here', 'EaW'
it does not produce the expected results. Am I doing something wrong?
nisus_writer_question_abt_look-behind_in_macros_20170806_sample_file.rtf
(19.16 KiB) Downloaded 1070 times
Re: Look-behind in macro
Hi Branner,
You say
Your Find and Replace code adds indeed a sub-item "b" after each sub-item "a", so I'm not sure what your problem is.
What are the "expected results" you're expecting?
Is it perhaps the additional text
which you don't want? If yes, then don't include it in the replace part. It should then look like this:
Find and Replace '(?<=a\.\t)(.+?)$', '\1\n', 'EaW'
or
Find and Replace @Text{(?<=a\.\t)(.+?)$$}, @Text<\1\n>, 'Ea'
I agree with Þorvarður. The macro gives the same result as doing the Find/Replace from the Find dialog for me. So I'm not sure what your think is going wrong.
A different problem which I really think Martin should have a look at, is that after this Find/Replace the selections are shifted. The first one is okay. The second starts at the dot of the auto-number and the third reaches even further back.
branner
Post by branner »
Indeed, it now works as expected. I don't know what went wrong — sorry for the trouble!
phspaelti wrote:A different problem which I really think Martin should have a look at, is that after this Find/Replace the selections are shifted. The first one is okay. The second starts at the dot of the auto-number and the third reaches even further back.
Thank you for calling this out Philip. You're right that the selection is off after the replacement for some matches. I'll take a look, thanks!
