Is there a manual?
eolake
Is there a manual?
Post by eolake »
I have looked on Google and on Nisus.com, and I have even emailed Nisus support, but I can't find any manual for NWE. Is there any? :?:
MacSailor
Re: Is there a manual?
Post by MacSailor »
eolake wrote:I have looked on Google and on Nisus.com, and I have even emailed Nisus support, but I can't find any manual for NWE. Is there any? :?:
You can download it at http://www.nisus.com/files/GetFileRedir ... ssGuidePDF
(moderator edit: corrected broken link)
Peter Edwardsson
eolake
Post by eolake »
Thanks.
Only I get a page with:
"Sorry, but that file is no longer available."
MacUnix
Post by MacUnix »
The link includes the [/url] from the WebBoard.
Remove that from the URL in the browser and it will download.
Or goto http://www.nisus.com/Express/ and under links select the 'Nisus Writer Express Guide'.
Ron
eolake
Post by eolake »
MacUnix wrote:The link includes the [/url] from the WebBoard.
Ron
Dude, you're right! Shame on me, I am usually good at spotting small tech things like that.
By the way: Nisus, you should make it easier to find the manual. And you should call it a "manual", not a "guide", so it will be easier to find using Search or Find.
eolake
Post by eolake »
OK, I got the manual now, and it looks very good and thorough, well done.
(I was actually 98% convinced there wasn't one. Glad I was wrong.)
MacSailor
Post by MacSailor »
Ron
The blame on me. I inserted the URL wrong, but I'm glad that MacUnix found out why it did not work. And I'm glad that eolake found the manual. 8)
Peter Edwardsson
