I would like to see the following:
greater integration with Nisus Express
The ability to activate links from within the eMail
Integration with the OS X address book (like PowerMail does) OR a way to extract addresses to your floating mail window (I love that thing)
I don't really need to see HTML in the mail window, will Express have this ability when completely integrated?
Are you considering the ability to select the encoding? I work in an almost exclusive windows environment with many different eMail clients as recipients and find that I need the flexibility to select encoding.
I love both products, Nisus EMail and Express beta. Keep up the great work. Glad to see you back on my computer (I dropped OS 9 years ago as I was an OSX beta tester).
