bug/error in 2.6
soulbarn
bug/error in 2.6
Post by soulbarn »
this is either a bug or a mistake, depending on how you interpret it. But it is clearly a problem! \\ :wink:
If you type a sentence in quotes, and close the quoted phrase with a comma and then a quote mark, ie:
"I love nisus," said the monkey.
Nisus interprets the close quote as a new open quote mark, rather than as a proper close quote mark (of course, this only happens if "smart quotes" is enabled in the Quick Fix section of preferences.)
I thought I might try a workaround on this - actually making a quick fix entry for comma-open quote to sub comma-close quote, but I guess quickfix only does plain text.
any way to fix this?
thanks,
Dan
cchapin
Post by cchapin »
This doesn't happen for me. The second quotation mark comes out as a closing quotation mark. I'm afraid I have no idea why it doesn't work properly in your case. Anybody?
--Craig
soulbarn
Post by soulbarn »
actually, I've noticed that it doesn't always happen for me, either. I'm able to reproduce it, but there seems to be no logical reason I can see (though there must be one, somewhere in the code, I guess) for one instance or the other.
Oh well.
If you can, send the document to expressfeedback@nisus.com and tell us where in the document the problem occurs exactly.
Mark XM
Post by Mark XM »
Whenever I have had this happen, I have found that it was because I had accidentally put a space in there that I hadn't noticed. You sure that's not the case with your texts?
